Assign Part Properties Individually
Assign part properties individually without the unified parts.
When the unified parts are not available, you need to specify the needed part properties separately for each part depending on the desired analysis type. To do this type of analysis, electrical properties are essential.
- Click Find by Ref Designator.
Enter the desired reference name and click OK.
The U204 component is highlighted.
Double-click the highlighted part
(H5TQ4G63AFR(DDR3).
The Electric & Thermal Properties dialog opens.
