To get a stable high signal transmission, plane as return path should be on adjacent
layers.
A shorter return path is better, but partial or split plane structure may alter
return path and make signal transmission unstable. You should avoid the high-speed
signal pattern on split plane. The image below depicts long return path results in
unstable signal transmission.
Figure 1. Longer return path for a signal over void
