Test Point2
Analyze the clearance between a test point and each component on a board.
More detailed information:
  • Test Point Definition
    • TP Component Group: Select a test point component group. Use if the test point is drawn as a component.
    • Pad TP in Route: Recognize a test point designed as a pad.
      • Size: Specify the pad size of the test point.
      • Padstack: Select the pad that will be used as a test point by using string filter.
        • Import(.txt): Apply Filter Type based on the characters entered in the .txt file.
          • Apply as a prefix when (|F|) ABC is entered in the .txt file.
          • Apply as a mid-string when ABC is entered in the .txt file.
          • Apply as a suffix when ABC(|P|) is entered in the .txt file.
        • Export(.txt): Export the characters registered in the String Item in .txt file format.
    • Via TP: Recognize a test point designed as a via.
  • Test Point Measure Base: Set a measurement base for the test point.
    • Shape: Select a measurement based on the pad shape of the test point.
    • Location: Select a measurement based on the center of the test point.
  • Checking
    • Clearance to the component group: Check the clearance Component Group.
      • Item: Specify the item name.
      • Component Group: Specify a component group.
      • Measure Base: Select a measurement base.
      • Clearance: Set the clearance between the test point and the component.
      • Placement: Select the disposed component in the specified layer for analysis.
      • Remainder: Set the analysis criteria for the remainder.
    • Clearance to the component height: Check clearance by recognizing component height information.
      • Measure Base: Set the Component measure base
      • Percentage to use as a clearance based on the component height: Determine Clearance based on Component Height x %
      • Acceptable clearance range: Set the clearance range Min,Max.
        • Minimum
        • Maximum
      • Exclude Component Group: Exclude Component Group from the list.
    • Placement Layer: Specify the layer for the disposed component.
