Pair Comp
This rule checks whether two specific components are connected.
There are occasions that components should be connected to certain signals and placed
together with other components.
- A transient load decoupling capacitor should be placed close to the device requiring the decoupled signal.
- A power supply decoupling bypass capacitor should be placed close to the voltage/current source.
- Placing a ferrite-bead close to the noise generating component pin helps reducing EMI.
- Item: Input item name.
- Comp1: Select 1st component group.
- Comp2: Select 2nd component group which should be exist with comp1.
- Net Group: Define component group that two components should be connected.
