Jump to main content
Altair SimSolid User Guide
2025
Index
  1. Home
  2. Connections
    Connections are used to define the association of different regions of interest between parts in an assembly.
  3. Welds
    Welding is a process that joins materials, usually metals by using heat or pressure.
  • Welcome
  • What's New
    View new features for SimSolid 2025.
  • Get Started
  • Tutorials
    Discover SimSolid functionality with interactive tutorials.
    Interfaces that support SimSolid output file format.
  • Geometry
    Information about treatment and properties of geometric entities in SimSolid.
  • Assembly
    Summary of available functionality for defining the properties and behavior of parts in the model.
  • Connections
    • Regular Connections
      Regular connections can be used to define contact-based connections between parts in an assembly.
    • Precise Connections
      SimSolid creates precise connections on the fly during geometry import and are grouped under the Precise connection folder.
    • Welds
      • Fillet and Seam Welds
        In SimSolid, seam welds are modeled as full 3D solid bodies.
      • Spot and Laser Welds
        A spot weld connects two parts over a circular area on the contacting surfaces. A laser weld connects the contacting surfaces over an area created from solids or strip created along a user-drawn line or a polyline.
    • Adhesives
      Structural adhesives are simulated as thin layers of adhesive material associated with a connection.
    • Virtual Connector
      Virtual connectors are rigid imaginary parts created between selected faces/spots representing geometrical support of the connector.
    • Connection Review
      A table that shows all connections in a specified design study.
    • Review Part Connection Locations
      Diagnose connection problems.
    • Review Part Connections
      Review connections on selected parts.
    • Show Disconnected Groups
      Identify groups of parts that are disconnected from the model.
  • Create Analysis
    Create an analysis for your project.
  • Boundary Conditions
    Boundary Conditions available for SimSolid.
  • Post Processing
    Run analyses and view a variety of results in SimSolid.
  • Design Study
    Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
  • Verification Problems
    Solved verification models.
  • Frequently Asked Questions
    This section provides quick responses to typical and frequently asked questions regarding
Welds
Below are the types of welds supported in SimSolid:
See Also
  • Seam Welds Video
© 2024 Altair Engineering, Inc. All Rights Reserved.
