Color-Code Objects
You can control the color, shininess, reflectivity, and transparency of individual objects in your scene to color-code the objects in your scene. With the exception of color, these properties do not appear when the scene is rendered.
- Select one or more objects.
- In the Model Browser, right-click one of the selected objects, and then select Color on the context menu.
To assign a color to the objects, clear the By Layer
check box, and then select a Color.
Note: To return to the default color that is assigned to curves and surfaces in the Preferences, click Default Color.
- Adjust the Shininess, Reflectivity, and Transparency of the objects.
