Run in Batch Mode
The batch mode option is especially useful for process automation, optimization, and other repetitive simulation tasks.
Run in Batch Mode on Windows
Invoke the script:
<installation_directory>\Activate_batch.bat,
and then enter either Twin Activate model files
(.scm files) or
OML scripts (.oml files)
as input arguments preceded with –f. For example, for an
OML script, enter Activate_batch.bat -f name.oml. For a
.scm file, enter Activate_batch.bat -f name.scm
Note: If the model file contains graphical windows, such as plot windows for
Scope blocks, the windows are not generated or displayed.
Run in Batch Mode on Linux
Invoke the script:
<installation_directory>/scripts/Activate_batch,
(.scm files) or
OML script, enter Activate_batch -f name.oml. For a .scm
file, enter Activate_batch -f name.scm
Batch Mode Start Options
| Option | Argument | Required or Optional | Description | Platform Support |
| -i | <space separated inputs> | Optional | Passes input(s) to scripts. These options can be accessed in
Twin Activate by the OML commands: getcmdinput and
getnumofcmdinputs. To pass cell arrays or
matrices on Linux, the open/close braces and semi-colons need to be
quoted.Linux
example: Windows example: |
All supported platforms. |
| -f | <filename>.<extension> | Required |
