OPTFEKO Options
Specify OPTFEKO command-line parameters using the GUI.
- Restart from solver run
- This option can be used if the optimisation process was terminated or interrupted and temporary files are available. Restart the optimisation at the number of the last incompleted optimisation number. No changes may be made to the model before restarting the optimisation process.
- Delete all files (except optimum)
- This option deletes all temporary files except the files related to the
optimum solution.Tip: Unselect this check box to allow resumption of an interrupted run.
- Number of processes to farm out
- This option allows you to specify the number processes to use per optimisation iteration when farming out the solution.
- Configure
- Specify the hosts and processes to be used when farming out the kernel
solution.
Figure 1. The Machines configuration dialog.
