Stitching Sheet Parts
Apply the stitch operation to ensure electrical connectivity for unconnected sheet parts.
- Select the sheet parts that you want to stitch.
On the Construct tab, in the Modify
group, click the
Stitch icon.
Figure 1. The Stitch Parts dialog.
- [Optional] Clear the Auto-calculate tolerance check box and in the Tolerance field specify the range over which adjoining faces are stitched.
- Click the Create button to stitch the faces and to close the dialog.
