Moving the Display of the Far Field Origin
Move the display of the far field origin to be more consistent with the location of the source.
- Select the 3D view and far field result that you want to modify.
On the 3D View contextual tabs set, on the
Result tab, in the Rendering group, click the
Offset icon.
On the Set display offset dialog specify new values for
the U, V and N coordinates.
Tip: You can use Ctrl+Shift+left click to click on the new origin for the far field.
Figure 1. A dipole and PEC structure with a far field with no offset (on the left) and a far field with an offset (to the right).
