Using a Single Zip Archive for Repo
Create a local Feko update repository using a single zip archive.
  1. Create the local repository folder, for example, C:\Updates.
    Note: If you already have an update repository for the same version, delete previous updates located in this folder.
  2. Download the updates for the required platforms from Altair Connect.
    For example, if both the Windows and Linux platforms are required, download the following:
    • FEKO_2025.1.1_WIN64_X86_64.zip
    • FEKO_2025.1.1_LINUX_X86_64.zip
  3. Copy the zipped archives to the local repository without extracting the files.
