BATTERY_GAS_VENTING_MODEL
Specifies a gas venting model.
AcuSolve Command
BATTERY_GAS_VENTING_MODEL("name") {parameters...}
- type (enumerated) [gas_release_file]
- Type of venting model.
- gas_release_file
- Read venting mass flow rate and temperature from a file.
- gas_reaction_model
- Solve ODE for cell gas pressure and dynamic release of gases.
- vent_gas_trigger_temperature (real) [=440.15]
- Temperature of the cell when the vent value opens.
- vent_gas_mass_flowrate_type (enumerated) [=none]
- Type mass flow rate data.
- none
- No mass flow rate experimental data.
- piecewise_linear or linear
- Piecewise linear curve fit of mass flow rate experimental data.
- cubic_spline or spline
- Cubic spline curve fit of mass flow rate experimental data.
- vent_gas_mass_flowrate_curve_fit_values (array) [={0,0}]
- A two-column array of mass flow rate experimental data values. The independent variable must be time. Used with piecewise_linear and cubic_spline types.
- vent_gas_mass_flowrate_curve_fit_variable (enumerated) [=time]
- Independent variable of the curve fit of mass flow rate venting experimental
data. Used with piecewise_linear and
cubic_spline types.
- time
- time
- vent_gas_temperature_type (enumerated) [=none]
- Type of temperature venting data.
- none
- No temperature experimental data.
- Piecewise linear curve fit of gas temperature experimental data.
- Cubic spline curve fit of gas temperature experimental data.
- vent_gas_temperature_curve_fit_values (array) [={0,0}]
- A two-column array of gas temperature experimental data values. The independent variable must be time. Used with piecewise_linear and cubic_spline types.
- vent_gas_temperature_curve_fit_variable (enumerated) [=time]
- Independent variable of the curve fit of temperature venting experimental
cubic_spline types.
- time
- time
- vent_gas_mass_flowrate_type_2 (enumerated) [=none]
- Type mass flow rate data for the second venting event during thermal
runaway.
- none
- vent_gas_mass_flowrate_curve_fit_values_2 (array) [={0,0}]
- A two-column array of mass flow rate experimental data values for the second venting during thermal runaway. The independent variable must be time. Used with piecewise_linear and cubic_spline types.
- vent_gas_mass_flowrate_curve_fit_variable_2 (enumerated) [=time]
data for second venting during thermal runaway. Used with
types.
- time
- time
- vent_gas_second_trigger_temperature (real) [=500]
- Temperature at which the battery vents again.
- vent_trigger_type (enumerated) [=temperature]
- Vent/burst disc opening method.
- temperature
- The vent opens when the vent_gas_trigger_temperature is reached.
- pressure
- The vent opens when the vent_opening_pressure is reached.
- vent_opening_pressure (real) [=2E6]
- Pressure at which the vent/burst disc opens.
- headspace_volume (real) [=1.158E-6]
- Volume of the headspace of the battery.
- heat_capcity_ratio (real) [=1.4]
- Ratio of specific heat for air.
- discharge_coefficient (real) [=0.8]
- Actual flow rate of a fluid through a constriction to the theoretical flow rate.
- electrolyte_molar_mass (real) [=0.09008]
- Molar mass of the electrolyte in kg/mol.
- gas_mixture_molar_mass (real) [=0.03]
- Molar mass of the gas mixture in the cell.
- initial_gas_moles (real) [=4.33E-5]
- Number of moles of gas present initially in the head space.
- vent_area (real) [=9.8E-6]
- Venting area of the cell.
- vent_gas_mass_fraction_generated (real) [=0.2]
- Mass fraction of generated gases in the gas mixture during venting.
- vent_gas_mass_fraction_electrolyte (real) [=0.1]
- Mass fraction of electrolyte in the gas mixture during venting.
- mols_of_generated_gas (array) [={}]
- An N stages array of gas generated in moles during each stage.
- dmc_coefficients (array) [={6.4338,1413,44.25}]
- Fitting coefficients for Antoine’s equation for the partial pressure of a dmc electrolyte vapor.
- vent_gas_number_substeps (integer) [=5]
- Sub-steps the time step size by dividing by this number when a vent is open.
- include_vent_gas_mass_loss (boolean) [=no]
- Boolean to enable/disable mass loss due to vented material. Mass loss is enabled when set to yes.
The BATTERY_GAS_VENTING_MODEL is developed to simulate gas venting from a battery cell during thermal runaway events. Battery cells are equipped with safety mechanisms, such as pressure relief valves or burst discs, to release accumulated gases when internal pressure rises during thermal runaway.
The example below illustrates the input format for a three-cell prismatic geometry, each equipped with a vent located at the top of the cell.
BATTERY_GAS_VENTING_MODEL("Venting_R1") {
type = gas_release_file
vent_gas_trigger_temperature = 440
vent_gas_mass_flowrate_type = linear
vent_gas_mass_flowrate_curve_fit_values = Read("ventMF.txt")
vent_gas_temperature_type = linear
vent_gas_temperature_curve_fit_values = Read("ventT.txt")
}In this model, the venting mass flow rate and temperature as a function of time are read from an external file. The vent valve is designed to open when the temperature reaches 440 K.
BATTERY_THERMAL_RUNAWAY_MODEL( "ThermalRunaway_4" ) {
formulation_type = lumped
ecm_model = no
type = arc_reaction_model
gas_venting_model = "Venting_R1"
}FEEDBACK_CONDITION("fbk1") {
type = volume
volume = "Cell1"
control_type = venting
FEEDBACK_CONDITION("fbk2") {
type = volume
volume = "Cell2"
FEEDBACK_CONDITION("fbk3") {
type = volume
volume = "Cell3"
}SIMPLE_BOUNDARY_CONDITION( "Vent3" ) {
surface_sets = {"Vent3_Interface_Air_tet_tria3" }
type = inflow
inflow_typem = mass_flux
feedback_condition = "fbk3"
