CAA_SURFACE_OUTPUT
Specifies a set of surfaces for CAA integrated-surface output.
AcuSolve Command
CAA_SURFACE_OUTPUT("name") {parameters...}
Qualifier
User-given name.
- caa_output (string) [no default]
- Qualifier of the CAA_OUTPUT command that outputs quantities integrated over the surfaces defined here.
- shape (enumerated) [no default])
- Shape of the surfaces in this set.
- three_node_triangle or tri3
- Three-node triangle.
- four_node_quad or quad4
- Four-node quadrilateral.
- partial_surfaces (array) [no default]
- List of surfaces with no references to elements or element sets.
- quadrature (enumerated) [=full]
- Quadrature rule used for surface integration.
- full
- Full quadrature.
- reduced
- Reduced quadrature.
CAA_SURFACE_OUTPUT( "sample surfaces" ) {
caa_output = "sample points"
shape = four_node_quad
partial_surfaces = { 1, 1, 2, 4, 3 ;
2, 3, 4, 6, 5 ; }
quadrature = full
}defines two surfaces that will contribute to any surface-integrated quantities specified in the CAA_OUTPUT command qualified by "sample_points". If there are no such quantities in the referenced command, then this command has no effect.
The partial_surfaces parameter contains the connectivity of the surfaces. This parameter is a multi-column array, but it does not have the same format as the corresponding parameter in other surface commands, for example, SURFACE_OUTPUT. The number of columns depends on the shape of the surface. For three_node_triangle, this parameter has four columns, corresponding to a unique (within this set) surface number and the three nodes of the surface. For four_node_quad, partial_surfaces has five columns, corresponding to a surface number and the four nodes of the surface. One row per surface must be given. Since there is no parent element definition the three or four nodes of the surface must be ordered around the periphery of the surface. Also unlike other surface commands this command does not support higher-order surfaces, that is, six-node triangles, or nodal quadrature. The nodes contained in the surface connectivity must all be defined in the referenced CAA_OUTPUT command.
1 1 2 4 3
2 3 4 6 5CAA_SURFACE_OUTPUT( "sample surfaces" ) {
partial_surfaces = Read( "sample.srf" )
quadrature = full
}A separate CAA_SURFACE_OUTPUT command must be issued for each surface shape and each CAA_OUTPUT command that references surface integrated quantities.
