Domain
In the domain section, the global definitions for the simulation are set, such as the number of dimensions and the numerical reference parameters.
Commands
domain
ndim 3
min_domain "0.0 0.0 0.0"
max_domain "1.0 3.0 0.0"
BC_min "OUTLET PERIODIC SIMPLEOUTLET"
BC_max "OUTLET PERIODIC SIMPLEOUTLET"
outlet_vel "0.05 0.0 0.0"
outlet_bodyforce_on true
ref_rho 1000.
ref_length 0.1
ref_vel 1.0
ref_curv 1.0
ref_visc 0.001
bodyforce "0.0 0.0 -9.81"
bodyforcefile bodyforcefile.txt
bodyforcefile_latch false
bodyframe_active false
bodyframe_states "1 2 3 4 5 6 7 8 9"
bodyframe_statesfile bodyframestatesfile.txt
bodyframe_statesfilelatch false
bodyframe_origin "0 0 0"
bodyframe_terms "0 0 0 0"
bodyframe_fallbackterms "0 0 0 0"
t_damp_bodyforce_start 0.0
t_damp_bodyforce_end 0.1
inputfile initialparticlepositions.prtl
inputfileReadMode INPTFL_AUTO
inputfile_type INPTFL_TAUTO
inputfile_factor 1.0
Command | Contents | SI Unit Example |
ndim | The dimensionality of the problem. 1 Options
min_domain | Minimum bounds of the computational box (vector defining a point
location). Note: If both min_domain and
max_domain are not specified in the
configuration file, the variables will be determined by the code
automatically. 1 |
max_domain | Maximum bounds of the computational box (vector defining a point
automatically. 1 |
BC_min | Boundary condition at the minimum boundary. For an illustration
of domain boundaries, refer to Comment 2. Options
Related Commands
BC_max | Boundary condition at the maximum boundary. For an illustration
Related Commands
outlet_vel | Specifies the velocity of the OUTLET boundary. Note:
outlet_bodyforce_on | If this flag is switched on, the outlet particles will experience
the prescribed body force. This is useful in cases where the outlet
plane is perpendicular to the body force (gravity) direction. In
these case, the zero gradient velocity at the outlet no longer applies. Options
ref_rho | Reference density. This should be the lowest fluid density in the
domain. Important: All reference values have been
automated. They can be set manually, as is recommended.
Depending on the case definition, the code will automatically
pick up the reference values, provided that the
max_dist command is defined in the motion
definition. Note: For density, the lowest fluid density is
picked up as the reference. Default = If not specified, the code will automatically detect it. |
ref_length | Reference length. A typical length scale defining the relevant
physics. Note: It is recommended that you specify this reference
value, as it can be difficult for the code to identify the
correct value in certain cases. For length, the code will
analyze the size of the domain in the direction of the body
force applied and choose that length as the reference length.
This means that if variable body force is being used, the
reference length is specified manually. Examples:
Default = The code will automatically try to find a relevant length for a hydrostatic problem. |
ref_vel | Reference velocity. Should be the highest expected velocity in
the domain. Note: For velocity, if there is defined motion in the
configuration file, the code will automatically calculate
maximum velocity of the motion, multiply it by a
ref_vel_factor (the default value is 1.5)
for conservative purposes, and set that value as the reference
velocity. If there is no motion defined, or if the motion is
rigid body or position file, the reference velocity must be
defined manually. Default = If the motion is defined in the .cfg file, the code will automatically calculate the maximum velocity and multiply it by the ref_vel_factor value in order to assure stable running of the simulation. |
ref_curv | Reference curvature (needed only if
surften_model is set to
ADAMI or SINGLE_PHASE). Should
be the curvature of the smallest droplet that needs to be resolved
(1/radius of the droplet). Note: For reference curvature, the default
curvature is set as 1/(5*dx). In order to
resolve droplets accurately, there needs to be a droplet radius
of at least five particles. Default = If not specified, the value is set to 1/(5*dx) Related Commands
ref_visc | Reference viscosity (needed only if
viscTempCoupling is set to true). Should be
the highest expected viscosity in the domain. Related Commands
bodyforce | Global acceleration field in inertial frame. Usually
gravity. Note: Body force vector must be specified (if using
variable body force file, the latter
bodyforcefile command will overwrite
it). |
[m/s^2] |
bodyforcefile | File bodyforcefile.txt contains the body force
vector as a function of time. Note: This is
simultaneously a switch for the code. If this command is
present, it will use the specified input file and ignore the
previous bodyforce input. Related
Commands
bodyforcefile_latch | Set to true to use the nearest value in the
bodyforcefile.txt file when current
simulation time is out of the time range defined in
bodyforcefile.txt. Default: false |
bodyframe_active | Set to true to activate simulation in body frame (moving
reference frame). When active, bodyforce keyword
can be used to specify the inertial frame states, for example
gravity. Use of bodyforcefile in conjunction with
body frame is not possible. Default: false |
bodyframe_states | States of the body frame with respect to inertial frame for three
directions (linear acceleration, angular acceleration and angular
velocity) in the order of "acc_x acc_y acc_z angacc_x
angacc_y angacc_z angvel_x angvel_y angvel_z". The
values are ramped from zero between
t_damp_bodyforce_start and
t_damp_bodyforce_end. Default: "0 0 0 0 0 0 0 0 0" |
[m/s^2 m/s^2 m/s^2 rad/s^2 rad/s^2 rad/s^2 rad/s rad/s rad/s] |
bodyframe_statesfile | File bodyframestatesfile.txt contains the
body frame states with respect to inertial frame as a function of
time. The file has 10 columns (time, linear acceleration vector
components, angular acceleration vector components, angular velocity
vector components) with the order "time acc_x acc_y acc_z angacc_x
angacc_y angacc_z angvel_x angvel_y angvel_z" . When present,
bodyframe_states,
t_damp_bodyforce_end are ignored.
Bodyforce keyword can be used to specify the
inertial frame states, for example gravity, with respect to inertial
frame as a function of time. Default: empty |
[s m/s^2 m/s^2 m/s^2 rad/s^2 rad/s^2 rad/s^2 rad/s rad/s rad/s] |
bodyframe_statesfilelatch | Set to true to use the nearest value in the
bodyframestatesfile.txt file when current
simulation time is out of the time range defined in body frame
states filebodyframestatesfile.txt. Default: false. |
bodyframe_origin | Initial origin of the body frame (moving reference frame) with
respect to inertial frame in [m]. Default: "0 0 0" |
[m] |
bodyframe_terms | Activation of fictitious terms with the order of "linear Euler
centrifugal Coriolis". Set an element to a positive number to
activate the relevant fictitious term in body frame (moving
reference frame). Default: "0 0 0 0" |
bodyframe_fallbackterms | Inclusion of fictitious terms with the order of "linear Euler
centrifugal Coriolis" in fallback reference length, speed of sound
and time step size. Set an element to a positive number to activate
the relevant fictitious term in body frame (moving reference
frame). Default: same as bodyframe_terms |
t_damp_bodyforce_start | Start time of the body force ramp-up process. Before this time, the body force is zero. Starting from this time, a body force is gradually increased. Note: Ramping up to the given
value is defined with t_damp_bodyforce_start
and t_damp_bodyforce_end
commands. Default = 0 |
t_damp_bodyforce_end | End time of the body force ramp-up process. This time must not be
smaller than t_damp_bodyforce_start. Within the
time interval between t_damp_bodyforce_start and
t_damp_bodyforce_end the body force is ramped
up to reach the full body force at
t_damp_bodyforce_end. At later times the full
body force is applied. Default = 0 |
inputfile | This file is the geometry input file (textfile) and needs to be present in the folder where the simulation is launched together with the config file. | |
inputfile_factor | This factor can be used to scale the input file
content. Note: nanoFluidX uses
SI-units. Therefore, this factor is useful if a model is created
in SimLab in millimeter-units and
needs to be converted to meters while reading in. Example:
Default = 1.0 |
inputfileReadMode | Describes the data format that is to be read in. Options
inputfile_type | Data file type of input particle file. Options
Note: Depending on the case,
ASCII type particle files have
a size of around 75 bytes per particle for the current format.
For binary type particle files, this reduces to 28 bytes per
particle, which translates to binary particle file sizes between
half and one third of equivalent ASCII type particle file
sizes. |
- If both min_domain and max_domain are not specified in the configuration file, the code will automatically detect the minimum and maximum dimensions of the case and create a bounding box automatically. This is useful when operating with closed geometry, such as a gearbox. To simulate a sloshing/splashing case where the fluid is not constrained within solid walls, or if there are periodic or inlet boundary conditions associated with the domain, it is necessary to manually prescribe the size of the domain (bounding box). [ndim, min_domain, max_domain]
- Each of the six bounding planes is
marked in a separate color, with the colored arrow showing the surface
normal of the boundary. The direction of these surface normals in the sketch
has no influence on the code execution, they are provided to help visualize
the domain. The two red dots at the opposite corners of the domain are
minimum and maximum extent of the domain. [BC_min, BC_max]
Figure 1. Sketch of nanoFluidX domain boundaries
