To facilitate post-processing with ParaView, nanoFluidX
and nFX[c] 2021.1 and above, Python state files must be
produced.
Load Results using State Files
To facilitate post-processing with ParaView, nanoFluidX and nFX[c] 2025.0 and above, Python state files must be produced. These state files are
intended as a starting point for post-processing needs and are fully compatible with
ParaView 5.12.1 and above. The state files are written to the
PVSTATE directory at the root of the case directory. Figure 1.
nanoFluidX state files reference files from
OUTPUT, PHASEINFO,
PROBE, and MOTION directories. nFX[c]
state file references files from postjobname and
MOTION directories. Currently there are four types of state
files:
Particle Data: particles.py
Interpolated Data: postjobname.py
Phase Integrated Data: phaseinfo_*.py
Probe Information: probeinfo_*.py
Particle Data - particles.py
This state file uses raw particle field data and may be slow.
Loads OUTPUT/particles.pvd and renames it to case
name.
Adds a Threshold filter per FLUID phase and renames them to
the phase name.
Adds an SPH Volume Interpolator per FLUID phase and sets
spatial steps and resolution to dx and interpolation volume extents to
domain size of the case.
Loads MOTION/motion_movingwalls.cfg UTM file, renames
it to MOVINGWALLS, and activates Ignore Time.
Adds an Extract Block filter to allow selective visualization of
MOVINGWALL phases.
Loads MOTION/motion_walls.cfg UTM file, renames it to
WALL phases and hides them.
MOTION/*.cfg files load relevant UTM and STL
files.
Interpolated Data - postjobname.py
These state file uses interpolated field data and is the recommended state files for
most post-processing needs.
Loads interpolated data:
nanoFluidX: Loads
name.
nFX[c]: Loads
postjobname/AllVars/interpData.pvd and
renames it to PostJobName.
MOVINGWALL phases.
files.
Phase Integrated Data - phaseinfo_*.py
This state file quickly plots the most frequently used variables in phaseinfo files
and circumvents the need to import data in Microsoft Excel or similar packages. The
state file may be used to follow the progress of a simulation during runtime.
Note: All other variables not plotted by default are also
accessible from the pipeline. Usable as of ParaView
5.12.1.
Loads all files under PHASEINFO and renames them to phasename Data.
Adds a Plot Data filter per file and renames them to phasename Plot.
Assigns a color to each variable in all phaseinfo files on a round robin
basis. This is intended to reduce the chances of repeating colors on the
same variable of different phaseinfo files.
Assigns a legend name to each variable as columnname phasename to help with
distinguishing the lines in plot layouts.
Adds a spreadsheet layout.
Adds the following layouts and sets the relevant axes titles per FLUID
phaseinfo:
Fluid Com: FLUID phase center of mass in X, Y, and Z.
Fluid nRho: number of particles satisfying and conditions for each FLUID
phase.
Probe Information - probeinfo_*.py
This state file quickly plots the most frequently used variables in probeinfo files
5.12.1.
Loads all files under PROBE and renames them to probename_probetype
Data.
Adds a Plot Data filter per file and renames them to probename_probetype
Plot.
Assigns a color to each variable in all probeinfo files on a round robin
same variable of different probeinfo files.
Assigns a legend name to each variable as columnname probename_probetype to
help with distinguishing the lines in plot layouts.
Adds the following layouts and sets the relevant axes titles per volume
probe:
Volprobe Pressure: pressure versus time for each volume probe.
Volprobe Density: density versus time for each volume probe.
Adds the following layouts and sets the relevant axes titles per surface and
flowrate probes:
Srf/flrprobe nPart: number of sampled particles versus time per
probe.
Srf/flrprobe Velocity: average velocity of the sampled particles
versus time per probe.
Srf/flrprobe Flowrate: total volume flowrate for all phases versus
time per probe.
Adds the following layouts and sets the relevant axes titles per solid
probe:
Sld probe Force: force versus time for each solid probe.
Sld probe Torque: torque versus time for each solid probe sampling a
MOVINGWALL phase.
Load Results from Individual Files
Particle Data - particles.pvd
Raw particle field data can be loaded by opening
/OUTPUT/particles.pvd.
Interpolated Data - interpData.pvd
Interpolated field data can be loaded by opening
/<postjobname>/AllVars/interpData.pvd.
Time Averaged Interpolated Data -
timeAverage_AllVars.vti
Time averaged interpolated field data can be loaded by opening
/<postjobname>/AllVars/timeAverage_AllVars.vti.
STL Wall Bodies - motion_walls.cfg and
STL files for the wall bodies can be loaded by opening
/MOTION/motion_walls.cfg and
/MOTION/motion_movingwalls.cfg.
Phase Information - phaseinfo_*.txt
Phase information can be loaded by opening
/PHASEINFO/<phasename_info.txt.
Probe Information - probeinfo_*.txt
Probe information can be loaded by opening
/PROBEINFO/<probename_info.txt.
