2025.1
Physics and theory for nanoFluidX.
Learn more about advanced solver features in nanoFluidX.
View new features for nanoFluidX 2025.1.
Discover nanoFluidX functionality with interactive tutorials.
Create a nanoFluidX model using SimLab.
nanoFluidX commands and parameters with examples.
Learn more about the physics features in nanoFluidX.
Learn more about the boundary conditions in nanoFluidX.
Learn more about the measurements features in nanoFluidX.
Standard SPH interpolation heavily depends on the basic premise that each particle has the so called full support. Full support implies that the owner particles can see particles all around itself within the smoothing length of the particle, which mathematically implies that the sum of the kernel, also known as Shepard coefficient, is equal to one.
Keychain validator compares the keychains in the .cfg file with valid nanoFluidX keychains, when activated.
The operationMode option allows you to change the solver for either minimal run time or maximum accuracy.
Sub-phasing capability, while essentially optional, represents structural change inside nanoFluidX more than a classic feature.
Some main principles and consequences of the transport velocity.
This glossary contains generic messages generated by nanoFluidX, their likely causes, and possible methods to resolve the related issues.
This section provides quick responses to typical and frequently asked questions regarding nanoFluidX.
References used throughout the nanoFluidX manual.
