Create and Manage Datasets
Datasets are collections of one or more simulation results used for training or testing a model.
Note: Dataset creation times vary because each solver result/input deck must be processed separately.
The following files are supported for PhysicsAI:
Table 1. List of Supported Files
Supported Solvers File Format
Abaqus .odb
AcuSolve .ensight
.h3d
ANSYS .rst
.rth
CCM+ .ensight
Custom/user-generated .ensight
.unv
.h3d
Fluent .ensight
LS-DYNA .d3plot
.d3eigv
Marc .t16
Nastran .op2
.h5
.xdb
PAM-CRASH .dsy
OptiStruct .h3d
.op2
Radioss .h3d
.anim
ultraFluidX .ensight
The required files based on the inputs and outputs to be used are summarized in Table 2.
Note: In Table 2, thickness and/or material is only for supported decks. See Custom Inputs: Global Hook or Custom Inputs: Nodal Hook for a list of supported decks.
Table 2.
Inputs Outputs Files Needed
Non-parametric Parametric Field result KPI and/or curve
Geometry Thickness and/or material Global property Nodal property
✓ x x x ✓ x Result files (.h3d, .odb, and so on)
✓ ✓ x x ✓ x Result files
Input decks (.fem, .rad, and so on) with the same name
✓ x x x x ✓ [Input deck or Result file]
.json file with the same name (outputs)
✓ ✓ x x x ✓ Input deck
✓ x ✓ x ✓ x Result file
.json with same name (inputs)
Global hooks
✓ x ✓ x x ✓ [Input decks or Result file]
.json with the same name (inputs and outputs)
Global hook
✓ x ✓ x ✓ ✓ Result file
Global hook
✓ ✓ ✓ x ✓ ✓ Input deck
Result file
Global hook
✓ ✓ ✓ ✓ ✓ ✓ Input deck
Result file
.csv file
Global hook
Nodal hook
✓ x x ✓ ✓ x Result file
.csv file
Nodal hook
✓ x x ✓ x ✓ [Input deck or Result file]
.json with the same name (outputs)
.csv file
Nodal hook
✓ x x ✓ ✓ ✓ Result file
.csv file
Nodal hook
✓ ✓ x ✓ ✓ x Input deck
Result file
.csv file
Nodal hook
✓ ✓ x ✓ x ✓ Input deck
Result file
.csv file
Nodal hook
✓ ✓ x ✓ ✓ ✓ Input deck
Result file
.csv file
Nodal hook
