2025.1
Discover HyperLife functionality with interactive tutorials.
Perform seam and spot weld fatigue analysis.
View new features for HyperLife 2025.1.
Learn how to access and download required model files.
Perform uniaxial fatigue analysis using S-N (stress-life) and E-N (strain-life) approaches for predicting the life (number of loading cycles) of a structure under cyclical loading.
Perform multiaxial fatigue analysis using S-N (stress-life), E-N (strain-life), and Dang Van Criterion (Factor of Safety) approaches for predicting the life (number of loading cycles) of a structure under cyclical loading.
Perform transient fatigue analysis using a S-N (stress-life) approach.
Perform random response fatigue analysis using a S-N (stress-life) approach.
Perform modal superposition fatigue analysis using a S-N (stress-life) approach.
Perform sine sweep fatigue analysis using a S-N (stress-life) approach.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explore additional post-processing options related to the input result files.
Explore verification problems for SN and EN with time series loading.
