2025.1
Discover HyperLife functionality with interactive tutorials.
Perform sine sweep fatigue analysis using a S-N (stress-life) approach.
View new features for HyperLife 2025.1.
Learn how to access and download required model files.
Perform uniaxial fatigue analysis using S-N (stress-life) and E-N (strain-life) approaches for predicting the life (number of loading cycles) of a structure under cyclical loading.
Perform multiaxial fatigue analysis using S-N (stress-life), E-N (strain-life), and Dang Van Criterion (Factor of Safety) approaches for predicting the life (number of loading cycles) of a structure under cyclical loading.
Perform seam and spot weld fatigue analysis.
Perform transient fatigue analysis using a S-N (stress-life) approach.
Perform random response fatigue analysis using a S-N (stress-life) approach.
Perform modal superposition fatigue analysis using a S-N (stress-life) approach.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explore additional post-processing options related to the input result files.
Explore verification problems for SN and EN with time series loading.
