Invoke HyperStudy
Run HyperStudy as a Standalone Product
To run on | Do this |
Windows platforms | From the Start menu, click or Drag and drop a .hstx study file into the HyperStudy icon on your desktop to open the study. |
PC from the DOS prompt | Run the following executable (where platform is
win64):
Linux platforms | Invoke via hst in <install_dir>/scripts/hst |
Run HyperStudy in Batch Mode
Windows platforms | Invoke via hstbatch.exe in <install_dir>/hwdesktop/hst/bin/winXX |
win64):
Linux platforms | Invoke via hstbatch in /Applications/AltairHyperWorks/2025.1/altair/scripts/hstbatch. |
HyperStudy Start Options
Option | Argument | Description | Supported Platform |
-archivefile | <filename>.hstx | Import the specified HyperStudy archive file. | All |
-delete | None | Deletes the contents of the run directory before each run. | All |
-editfile | <filename> | Launch the HyperStudy
Editor without having to open
HyperStudy entirely. <filename> is an optional name of the file to open in the Editor. |
All |
-ex | None | Experimental mode (Ctrl-Alt e). | All |
-h or -help or -H |
None | Executable documentation. | All Use -H on Linux |
-logfile | <filename> | Enable the writing of logfile. If no file specification is provided, a default name will be created ( hyperstudy_log_<pid>.txt) in your $HOME area or current working directory if ${HOME} is not defined. |
All |
-multiexec | Number of concurrent jobs | Run HyperStudy batch mode with the multi-execution option. | All |
-nobg | None | Run HyperStudy in the foreground and not in the background. | Linux |
-o | filename1 | Used in conjunction with unit testing. | All |
-overwrite | None | Overwrite existing files and directories. | All |
-preffile | filename2.mvw | Preferences file for batch _run. | All |
-s | None | Display application status information. For diagnostic purposes, –v –s can be used in combination to run in dual mode on Windows. On UNIX, use the –nobg –s option when using the startup script. |
All |
-studyfile | filename3.hstudy | Load an .hstudy file upon opening HyperStudy from the command line. | All |
-v | None | Incrementally adjust the Verbose flag (Ctrl-Alt v). | All |
-wait | None | Pause the console window. | Windows |
