2025.1
View new features for version 2025.1.
The Python API documentation for HyperMesh applications.
Finds the closest node for the specified point coordinates.
Gets a ComplexCtrl handle of an animation client model.
Gets a component handle of an animation client model.
Gets a list of existing components.
Gets a ContourCtrl handle of an animation client model.
Gets a ContourLegend handle of an animation client model.
Returns the current simulation.
Returns the current subcase.
Gets a page handle.
Gets an explosion handle of an animation client.
Gets an FLD case study handle.
Gets an FLDCtrl handle of an animation client model.
Gets an H3D options handle of an animation client.
Gets an ID list from a given selection set.
Gets an iterator handle to a query handle.
Gets a SystemHandle to the LocalSystem in an animation client.
Displays a contour result.
Gets a measure handle of an animation client model.
Gets a model handle of the animation client.
Sets the phase angle of the current animation window.
Gets a query handle of an animation client model.
Gets the current time of an animation.
Gets a render options handle of an animation client.
Gets a ResultCtrl handle of an animation client model.
Gets a Scale Control handle of an animation client model.
Gets a section handle of an animation client model.
Gets a SelectionSet handle of an animation client model.
Returns all simulations for a subcase that are contained in the current model/results.
Returns a Subcase handle to the belonging Subcase ID.
Returns all subcases that are contained in the current model/results.
Gets a system handle of an animation client model.
Gets a TensorCtrl handle of an animation client model.
Gets a TensorLegend handle of an animation client model.
Gets a tracking system handle of an animation client model.
Gets a VectorCtrl handle of an animation client model.
Gets a VectorCtrl handle of the active animation client model.
Returns ID’s of HyperView entities marked with HWC.
Interactive entity selection context that returns either an ID list or selection sets.
Use the Task Manager to load an XML file that defines tasks and their attributes.
