2025.1
View new features for version 2025.1.
The Python API documentation for HyperMesh applications.
Gets a curve handle.
Gets an axis handle of a plot client.
Gets a header handle of a plot client.
Gets a footer handle of a plot client.
Gets a footer font handle of a plot client.
Gets a header font handle of a plot client.
Gets a legend handle of a plot client.
Gets a vector handle.
Gets a verticle datum handle of a plot client.
Use the Task Manager to load an XML file that defines tasks and their attributes.
