2025.1
View new features for Altair HyperWorks 2025.1.
A graphical manipulator allows you to modify specific items directly in the graphics area using interactive tools.
HyperView supports stereoscopic 3D viewing to visualize simulation data in 3D.
HyperView uses scalable fonts for Linux to render text in the 3D window.
A right-click in the graphics area displays a context menu which provides access to various options is available in HyperView.
A new workflow emphasizing the multicore profile for post processing results from certain solvers and crash use cases.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
