2025.1
Explore the different types of 3D mesh you can create in HyperMesh.
Explore the tools used to create solid mesh.
View new features for Altair HyperWorks 2025.1.
Each element has an associated element configuration. An element configuration tells HyperMesh how to draw, store, and work with the element.
Solver cards supported for elements.
Use the Element Quality view to review element quality while simultaneously editing your model.
Explore the different types of 1D mesh you can create in HyperMesh.
Explore the different types of 2D mesh you can create in HyperMesh.
Supported 3D elements.
Explore the tools used to create 3D mesh.
Use the Tet tool to fill an enclosed volume with first order or second order tetrahedral elements.
Use the Map tool to create and edit a mesh of solid elements in a solid geometric volume.
Use the Thin Solids tool to create 3D mesh on thin solids. The mesh is created by first generating a 2D mesh on a selected set of source faces, and then extruding this mesh to generate solid hexa or wedge elements.
Acoustic cavity meshing for interior noise generates a fluid volume mesh used to calculate the acoustic modes (or standing waves) inside the air spaces of a vehicle or similarly enclosed structural model.
Acoustic cavity meshing for exterior noise generates a fluid volume mesh and boundary mesh used to calculate the acoustic modes, or standing waves, in the external air spaces of a powertrain, e-motor or similarly enclosed structural model.
Explore the tools used to edit 3D mesh.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
