2025.1
View new features for Altair HyperWorks 2025.1.
Create an assembly structure from a .csv file definition.
Use the Create Properties/Beam sections For Each Element tool to create a new property with the same ID as the element by copying the existing 1D and 2D element property and assigning it to the component/part.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
