2025.1
View new features for Altair HyperWorks 2025.1.
The following file types can be read, depending upon the active application.
Create a new file.
Open a file.
Import various file types into the selected client.
When loading an .hm file, you may receive a warning message depending on the version and solver interface in which the file was last saved.
Load a different solver interface in the application.
Convert model files from one solver format to another.
Batch mode conversion is available for all solver interfaces.
The Abaqus to Nastran conversion uses an open conversion scheme; you can specify different mappings in the configuration file.
The Abaqus to OptiStruct conversion uses an open conversion scheme; you can specify different mappings in the configuration file.
Load command files, scripts, solver template files, preferences, or the Metadata Table.
Save all of the data in your current session.
The Diagnostics Information Gathering utility collects diagnostics files in the case of a crash and saves them to a common folder.
Export various file types from the selected client to another format.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the main input deck.
Templates can be imported by means of the File > Import menu.
Record a video or take a snapshot of the screen.
Use the Units tool to convert a finite element model from its initial unit system to a new unit system.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
