2025.1
Plot data can be post-processed using both HyperMesh and HyperGraph.
Add horizontal and vertical datum lines to plots.
View new features for Altair HyperWorks 2025.1.
The Developer ribbon contains tools for automation and customization.
Use the Chart Manager to plot your analysis results.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Plot curves for multiple runs and multiple subcases for a component.
Create and edit curves.
Create macros that produce curves and notes for plots.
Edit curves within a specified range and orientation.
Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed in the dialog.
Calculates statistics over a specified range on a curve.
Annotate plots using notes.
Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move panel.
