Tip to Tail
Displayed immediately upon curve selection, this tool calculates and draws the tip to tail function based on the current plot.
From the Vector Chart ribbon, click the Tip To Tail tool.
Based On
Select Off, All, Displayed, or Selected to determine the curve(s) that defines the tip to tail function.
Off
No vectors are selected and manual selection of curves is not permitted. No resultant is displayed.
All
Bases the definition on all curves in the session. Manual selection of curves is not permitted.
Displayed
Bases the definition only on the curves displayed in the window. You can select curves manually. To remove a curve from the calculation process, select the curve(s) from the Available curves list and click the forward arrow, , to move the curve(s) to the Exclude column.
Selected
Bases the definition only on the curves that you select from the list.
Available Curves
Lists the available curves in the current session.
All
Click All to select all curves in the list.
None
Click None to deselect all highlighted curves in the list.
Flip
Click Flip to exchange the currently selected curves for the unselected curves in the list.
Exclude
Lists the curves that you have selected for exclusion from the Available curves list.
These curves are not included when defining the tip to tail function.
To return a curve back to the Available curves list, select it from the Exclude list and click the back arrow, .
Display Attributes
Select a curve or curves from the Available curves list and select a line style or line thickness from the color palette to change the display attributes of the selected vector.
Select Use preferences to use the default preference file in the current session.
