2025.1
Plot data can be post-processed using both HyperMesh and HyperGraph.
Annotate plots using notes.
View new features for Altair HyperWorks 2025.1.
The Developer ribbon contains tools for automation and customization.
Use the Chart Manager to plot your analysis results.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing bar charts individually and add new bar charts to the current plot.
Add horizontal and vertical datum lines to plots.
See Notes for more information.
