2025.1
Create and edit points, bodies, lines (curve graphics), solids (graphics), markers and vectors, edit grounded/ungrounded bodies, create and edit rigid body groups, configure gravity, and select material properties.
Use the Graphics tool to create and edit visualizations for entities during pre-processing and post-processing.
View new features for Altair HyperWorks 2025.1.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
Create and edit systems, assemblies, and analyses, use wizards to build models quickly, create and edit belt/pullies, NLFE stabars, and NLFE springs, access the EDEM and Track Builder tools.
Use the Points tool to create and edit individual points, points on a vector, points along a curve, points at the center of a circle, and parametric points.
Use the Bodies tool to create and edit rigid, point mass, and deformable/flexible bodies.
The total mass, center of gravity, and inertia of the models or bodies within a model can be quickly obtained through the CG/Inertia Summary utility.
Use the tool to create curve graphics from a set of selected points or nodes. The generated curve graphics can be used to setup 2D rigid to rigid contact or advanced joints, such as point to curve or curve to curve joints. Based on the selected set of points or nodes belonging to a file graphic or CAD graphic, this tool creates a 3D cartesian curve and a curve graphic.
A curve graphic is created by positioning a 3D curve entity (Cartesian or parametric curve) in a reference frame (marker). The reference frame can be an explicit marker or can be implicitly defined using a body-point-orientation method.
A DeformableRoad type graphic can be used in conjunction with a tire and topics/chapter_heads/soft_soil_r.html road in vehicle models.
The file graphic type is used when realistic shapes of the bodies of the mechanism are to be included in the model.
A graphic system entity acts similar to that of a general system entity - it is intended to be used as a container for graphic entities, and it can be used repetitively. Like general systems, graphic systems can use attachments that refer to entities that are external to the system - this allows you to use them repetitively by parameterizing the body, point, etc. that are typically needed to define the graphics within the graphic system.
From the Graphics panel’s Visualization tab, you can modify the visual attributes of the graphic types.
Use the Primitives tool to create and edit visualizations for entities during pre-processing and post-processing.
Use the Markers tool to create coordinate systems and reference frames.
Use the Vectors tool to create and edit vectors.
Use the Ground tool to change a rigid body or a rigid group to a grounded state.
Use the Rigid Groups tool to group bodies into a rigid group.
Use the tool to view, add, and edit the material properties that are used for NLFE bodies.
Create and edit various model entities.
Create and edit outputs, create and edit templates, run the solver, view reports, access the Load Export utility, use the Optimization Wizard, open HyperStudy, utilize many pre-processing and post-processing capabilities with regards to flexible bodies (or flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
