Edit Mesh Biasing and Element Size Distribution
Use the Freeform: Biasing tool to apply linear, exponential, or bellcurve biasing to individual edges of a surface, and edit the elements size distribution.
Before you begin, use the Freeform: Create tool to define a meshing area by selecting surfaces, and create an initial mesh.
Element biasing can be used to improve element quality when transitioning from smaller to larger element sizes, and enables you to moderate the changes in aspect ratio from the start to the end.
After you have created an initial mesh, bias the placement of nodes so that their intervals are not uniform in size. For example, you can designate that the smaller intervals go near the start of the edge, near the end of the edge, near both ends with larger intervals in the middle, or near the middle of the edge.
  1. From the 2D ribbon, click the Freeform > Biasing tool.
  2. Optional: On the guide bar, click to define surface mesh options.
  3. Left-click to select the edge(s) to modify.
  4. In the microdialog, click the icon to select an element biasing type.
  5. Edit magnitude in the following ways:
    • Increase individual edge values by holding Ctrl while left-clicking on an edge; decrease individual edge values by holding Ctrl while right-clicking on an edge.
    • Scroll edge values by holding Ctrl while scrolling the mouse wheel up and down. Hovering directly over an edge will only modify that edge; hovering over empty space will modify all selected edges.
    • Specify an edge value in the microdialog and press Enter. If multiple edges are selected, a common value will be applied. If multiple edges with different edge values are selected, use the arrows in the microdialog to modify individual edge values simultaneously, without applying a common value.
  6. On the guide bar, click Update
Tip: Clear your selection by left-clicking in empty space.
Element Biasing
The automeshing process enables you to bias the placement of nodes so that their intervals are not uniform in size.
You can designate that the smaller intervals go near the start of the edge, near the end of the edge, near both ends with larger intervals in the middle, or near the middle of the edge.
Within the automesher, you may want to use biasing to improve element quality when transitioning from smaller to larger element sizes. In Linear Solids, the mesh at one end could be scaled several times larger than at the other end. Element biasing allows you to moderate the changes in aspect ratio from the start to the end.
Linear Biasing
In linear biasing, the biasing intensity corresponds to the positive slope of a straight line over the interval [0,1] of the Real Line. This interval is uniformly divided into as many subintervals as specified by the element density and they are mapped along the edge so that the length of the image interval is proportional to the height of the line over the midpoint of the source interval. Each image interval corresponds to the side of an element.
Specifically, let n be the element density and let .
We want a node placement function x(s) taking values in [0,1] with x(0) = 0 and x(1) = 1. If m is the slope of the line, and b is its y-intercept, then:
Using x(0) = 0, and x(1) = 1, we find: so,
For this, m is the absolute value of the biasing intensity. If the biasing intensity is negative, the nodes are placed according to 1 - x(s). Thus, a positive biasing intensity puts small elements at the start of the interval.
We can use b to scale the behavior of the function so that convenient values are in the range [0,20]. The value used is b = 1.5.
Exponential Biasing
In exponential biasing, the sizes of the intervals grow geometrically, progressing along the edge, with each successive interval being a constant factor larger than the previous. That factor is 1.0 plus 1/10 of the absolute value of the biasing intensity. This formula was chosen so that an intensity of zero will still represent no biasing, and convenient values will fall in the range [0,20]. Negative biasing intensities just reverse the edge, placing the smaller elements at the end instead of the beginning.
We want a node placement function x(s) taking values in [0,1] with x(0) = 0 and x(1) =1.
Let be the geometric growth factor.
We need a function so that:
Let then:
which gives the proper interval lengths,
then x(s) scales them to the range of [0,1]. Thus, .
Bell Curve Biasing
In bell curve biasing, nodes are distributed long the edge in a pattern that is symmetric across the midpoint of the edge. If the biasing intensity is positive, the smaller intervals are placed at the beginning and end of the edge, and if it is negative, they are placed at the middle of the edge.
Specifically, let n be the element density and .
We need so that
takes values in [0,1] with x(0) = 0, x(1) = 1, and has the behavior noted above. If we use:
for positive biasing intensity r, then x(s) becomes:
where erf() is the statistical error function,
