POLY
The POLY function evaluates a standard polynomial at a specific value .
<Motion_Joint
id = "301001"
type = "EXPRESSION"
val_type = "D"
expr = "POLY(TIME,0,1,2,3)"
joint_id = "10003"
joint_type = "R"
/>Arguments
- The independent variable. For example, to specify time as the independent variable, specify as TIME.
- The shift in the polynomial.
- The coefficients in the polynomial. Specify only as many coefficients as needed with a maximum of 31 coefficients.
Definition
