Run MotionSolve from MotionView
The Run Solver panel in MotionView allows you to run MotionSolve directly from MotionView.
You can either run the current model or run an existing MotionSolve command file generated previously by MotionView.
From the MotionView Solver Mode menu, select
MotionSolve to make MotionSolve the current solver.
Figure 1. Run Solver Panel with the MotionSolve
Solver Selected
Figure 2. Run Solver Panel with the MotionSolve
File Option Selected
