Force: Spring Damper
Command ElementModifies a spring-damper force element.
<Force_SpringDamper
id = "integer"
i_marker_id = "integer"
j_marker_id = "integer"
stiffness = "real"
damping = "real"
length = "real"
preload = "real"
/>Attributes
- id
- Element identification number (integer > 0). This number is unique among all Force_SpringDamper elements.
- i_marker_id
- Modifies the Reference_Marker at which the force or torque is applied. This is designated as the point of application of the force.
- j_marker_id
- Modifies the Reference_Marker at which the reaction force or torque is applied. This is designated as the point of application of the reaction force.
- length
- Modifies the free-length or the installed (reference) length of the spring. It has to be strictly positive. A zero or negative value is not allowed.
- stiffness
- Modifies the spring stiffness. For translational spring-dampers, this has units of force/unit translational deflection. For rotational spring-dampers, this has units of torque/radian. Note that stiffness > 0. A negative value is not allowed.
- damping
- Modifies the damping coefficient. For translational spring-dampers, this has units of force/unit translational deflection velocity. For rotational spring-dampers, this has units of torque/unit angular deflection velocity.
- preload
- Modifies any assembly or pre-load in the spring-damper. This is the force or torque when the distance or angle between the I and J markers is equal to the value specified by length.
<Force_SpringDamper
id = "105001"
length = "334.12"
stiffness = "138.444"
damping = "0."
preload = "0."
