/FAIL/XFEM_TBUTC (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
/FAIL/XFEM_TBUTC/mat_ID/unit_ID
γ K σ r Ifail_sh Iduct
a b
Optional Line
fail_ID
Definition
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit identifier
γ Exponent
(Real)
K Critical damage integral
Default = 1030 (Real)
σ r Fracture stress
[ Pa ]
Ifail_sh Shell failure flag
= 1 (Default)
Shell is cracked (not deleted), if D ≥ K for one integration point.
= 2
For each integration point, the stress tensor is set to zero, if D ≥ K; and shell is cracked (not deleted), if D ≥ K for all integration points.
(Integer)
Iduct Ductile-brittle materials flag
= 1 (Default)
If a ductile material is used
= 2
If a brittle material is used
(Integer)
a Material parameter (exponent)
(Real)
b Material parameter (exponent)
(Real)
fail_ID (Optional) Failure criteria identifier 5
  1. This failure model is available for Shell only.
  2. An element fails once the Tuler-Butcher cumulative damage parameter is greater than the stated critical damage value, K. The damage parameter accumulation is calculated differently for ductile and brittle materials (Iduct = 1 or 2).
    For ductile materials, the cumulative damage parameter is:
    D = ∫ 0 t ( σ − σ r ) λ dt
    Where,
    σ r
    Fracture stress
    σ
    Maximum principal stress
    λ
    Material constant
    t
    Time when shell cracks for initiation of a new crack within the structure
    D
    Damage integral, another material constant
  3. For brittle materials, the damage parameter is:
    D ˙ = 1 K ( σ − σ r ) a
    σ r = σ 0 ( 1 − D ) b
    D = D + D ˙ Δ t
  4. Current known limitations are:
    • /PARITH/ON does not ensure results repeatability, if SPMD > 1; it works in SMP parallel mode only.
    • XFEM is currently NOT compatible with either /ANIM/VECT or with /PARITH/OFF.
  5. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
