/INIBRI/FAIL
Block Format Keyword Describes the failure criteria for a brick.
/INIBRI/FAIL/unit_ID | |||||||||
brick_ID | Nlay | nptr | npts | nptt | lay_ID | fail_ID | Ifail_typ | Nvar | mat_ID |
V1 | etc | etc | |||||||
VN |
Definition
unit_ID | Unit identifier. (Integer, maximum 10 digits) |
brick_ID | Element
identifier. (Integer) |
Nlay | Number of
layers. (Integer) |
nptr | Number of integration
points in direction r. (Integer) |
npts | Number of integration
points in direction s. (Integer) |
nptt | Number of integration
points in direction t. (Integer) |
lay_ID | Layer to initialize
fail_ID | Failure criteria to
initialize identifier. (Integer) |
Ifail_typ | Failure criteria to
initialize type. 5 (Integer) |
Nvar | Number of failure criteria
variables to initialize. (Integer) |
mat_ID | Material identifier to
V1 | First failure criteria
variable value. (Integer) |
VN | Nth
failure criteria variable value (3 values per
line). (Integer) |
- If nptr > 1, npts > 1, nptt > 1, the lines with real values have to be repeated for each integration point.
- Nvar values needs to be written for each integration point of the elements as a block of Nvar variable Vi with 3 variables per line.
- The total number of integration points in the element is: .
- The integration points are ordered from
nptr, npts and
nptt.
Example for 4 integration points in (r,s,t): (1,1,1), (1,1,2), (1,2,1), (1,2,2), (2,1,1), (2,1,2), (2,2,1), (2,2,2).
- Every
failure model has a Ifail_typ which is used to identify the
failure model to initialize for the element. Verify failure law to element type
compatibility in /FAIL.
- Keyword
- Ifail_typ
- /FAIL/ALTER
- 28
- /FAIL/BIQUAD
- 30
- /FAIL/CHANG
- 13
- /FAIL/COCKCROFT
- 34
- /FAIL/CONNECT
- 20
- /FAIL/EMC
- 27
- /FAIL/ENERGY
- 11
- /FAIL/FABRIC
- 31
- /FAIL/FLD
- 7
- /FAIL/FRACTAL_DAMAGE
- 12
- /FAIL/GENE1
- 39
- /FAIL/GURSON
- 35
- /FAIL/HASHIN
- 14
- /FAIL/HC_DSSE
- 32
- /FAIL/HOFFMAN
- 46
- /FAIL/INIEVO
- 42
- /FAIL/JOHNSON
- 1
- /FAIL/LAD_DAMA
- 18
- /FAIL/MAXSTRAIN
- 47
- /FAIL/MULLINS_OR
- 33
- /FAIL/NXT
- 25
- /FAIL/ORTHBIQUAD
- 38
- /FAIL/ORTHENERG
- 48
- /FAIL/ORTHSTRAIN
- 24
- /FAIL/PUCK
- 16
- /FAIL/RTCL
- 40
- /FAIL/SAHRAEI
- 29
- /FAIL/SNCONNECT
- 26
- /FAIL/SPALLING
- 8
- /FAIL/SYAZWAN
- 43
- /FAIL/TAB1
- 23
- /FAIL/TAB2
- 41
- /FAIL/TBUTCHER
- 2
- /FAIL/TENSSTRAIN
- 10
- /FAIL/TSAIHILL
- 45
- /FAIL/TSAIWU
- 44
- /FAIL/USER1
- 4
- /FAIL/USER2
- 5
- /FAIL/USER3
- 6
- /FAIL/VISUAL
- 36
- /FAIL/WIERZBICKI
- 9
- /FAIL/WILKINS
- 3
