Engine Keyword Describes the implicit dynamics with
-HHT method.
/IMPL/DYNA/1
Definition
| Field |
Contents |
SI Unit Example |
Implicit dynamic with
(HHT method). (-1/3 <
< 0)
=0 set to -0.05 |
- The nonlinear parameters, rather
than default values can be defined in /IMPL/NONLIN/N.
- An
-HHT method is the default implicit dynamic method, if /1 is omitted.
