- /IMPL/AUTOSPC
Engine Keyword A zero stiffness DOF will be constrained automatically.
- /IMPL/DIVERG/n
Engine Keyword Divergence criterion with successive increasing residual number for nonlinear analysis.
- /IMPL/DYNA/1
Engine Keyword Describes the implicit dynamics with
-HHT method.
- /IMPL/DYNA/2
Engine Keyword Describes the implicit dynamics with a general Newmark method.
- /IMPL/DYNA/DAMP
Engine Keyword Rayleigh structure damping with dynamic implicit analysis.
- /IMPL/GSTIF/OFF
Engine Keyword Geometrical stiffness matrix will not be used for implicit nonlinear calculation.
- /IMPL/INTER/KCOMP
Engine Keyword Describes the stiffness matrix; due to contact interfaces will be assembled completely.
- /IMPL/INTER/KNONL
Engine Keyword Defines including some contact nonlinearities in PCG linear solver.
- /IMPL/LINEAR/INTER
Engine Keyword Implicit linear analysis will take into account contact interfaces.
- /IMPL/LSEARCH/OFF
Engine Keyword Deactivating line search for nonlinear analysis.
- /IMPL/LSEARCH/n
Engine Keyword Line search methods for nonlinear analysis.
- /IMPL/MONVOL/OFF
Engine Keyword Describes the stiffness of gas in monitored volume type 3 (tire modeling).
- /IMPL/MUMPS/AUTOCORE
Engine Keyword MUMPS solver will automatically switch from in-core memory to out-of-core memory.
- /IMPL/MUMPS/OUTCORE
Engine Keyword MUMPS solver will use minimum in-core memory.
- /IMPL/NCYCLE/STOP
Engine Keyword The computation will be stopped, if Ncy_max is reached.
- /IMPL/PREPAT
Engine Keyword Describes the implicit option for pre-conditioning.
- /IMPL/PSTIF/OFF
Engine Keyword Deactivating load (pressure) stiffness matrix.
- /IMPL/RREF/INTERF/n
Engine Keyword Different reference force residual computations used for stop criteria on nonlinear analysis with contact.
- /IMPL/RREF/LIMIT
Engine Keyword Define reference force residual limit values used in stop criteria for implicit nonlinear.
- /IMPL/RREF/OFF
Engine Keyword Deactivation reference residual option and using the previous one in stop criteria for implicit nonlinear analysis.
- /IMPL/SHPOFF
Engine Keyword The full projection of QEPH shell element for warped elements will be deactivated to keep consistency between the stiffness matrix and the internal force computations.
- /IMPL/SHPON
Engine Keyword The full projection of QEPH shell element for warped elements will be activated for stiffness matrix to keep consistency with the internal force computations.
- /IMPL/SINIT
Engine Keyword Describes the initial stresses that will be imposed gradually.
- /IMPL/SPRBACK
Engine Keyword Implicit spring-back will be run in this session.
- /IMPL/SPRING
Engine Keyword Describes the linear or nonlinear stiffness choices for nonlinear spring in implicit nonlinear analysis.
