/MAT/LAW122 (MODIFIED_LADEVEZE)
Block Format Keyword A simple unidirectional composite ply model, accounting for orthotropic elasticity and plasticity. Fiber and matrix damage are considered, including strain rate effect.
| /MAT/LAW122/mat_ID/unit_ID or /MAT/MODIFIED_LADEVEZE/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| ISH | ITR | IRES | |||||||
| M | A | ||||||||
| IBUCK | |||||||||
| IFUNCD1 | b | ||||||||
| DMAX | |||||||||
| IFUNCD2 | |||||||||
| IFUNCD2C | |||||||||
| LTYPE11 | LTYPE12 | LTYPER0 | |||||||
| FCUT | |||||||||
Definition
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | (Optional) Unit identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial
density. (Real) |
| Young’s modulus in fiber direction
1 for tension. (Real) |
| Young’s modulus in matrix direction
2. (Real) |
3. (Real) |
| Shear modulus in the plane
12. (Real) |
23. (Real) |
13. (Real) |
| Poisson’s ratio in the plane
12. (Real) |
23. (Real) |
31. (Real) |
1 for compression. (Real) |
| Compressive factor of the modulus
correction. (Real) |
| ISH | Shear matrix damage flag.
(Integer) |
| ITR | Transverse matrix damage flag.
(Integer) |
| IRES | Return mapping algorithm flag.
(Integer) |
| Initial yield stress. Default = 1020 (Real) |
| Hardening
modulus. (Real) |
| M | Hardening
exponent. (Real) |
| A | Shear and transverse plasticity
coupling factor. (Real) |
| Tensile initial damage strain in
fiber direction 1. Default = 1020 (Real) |
| Tensile ultimate damage strain in
fiber direction 1. Default = 2*1020 (Real) |
| Tensile ultimate damage in fiber
direction 1. (Real) |
| Compression initial damage strain
in fiber direction 1. Default = 1020 (Real) |
| Compression ultimate damage strain
in fiber direction 1. Default = 2*1020 (Real) |
| Compression ultimate damage in
fiber direction 1. (Real) |
| IBUCK | Buckling damage matrix on fiber in
compression flag.
(Integer) |
| IFUNCD1 | Matrix shear tabulated damage
function identifier. (Integer) |
| Damage saturation for matrix shear
exponential damage. (Real) |
| Initial matrix shear damage
threshold / Abscissa scale factor for tabulated
damage. Default = 1020 or 1.0 (Real) |
| Critical matrix shear damage
limit. (Real) |
| b | Shear/transverse matrix damage
coupling factor. Default = (Real) |
| DMAX | Damage maximum allowed
value. (Real) |
| Elementary shear damage
value. Default = 1020 (Real) |
| Brittle damage limit for
fiber-matrix interface. Default = 1020 (Real) |
| IFUNCD2 | Tension transverse matrix tabulated
damage function identifier. (Integer) |
| Damage saturation for transverse
matrix exponential damage in tension. (Real) |
| Initial transverse matrix damage
threshold in tension / Abscissa scale factor for tabulated
| Critical transverse matrix damage
limit in tension. (Real) |
| IFUNCDC2 | Compression transverse matrix
tabulated damage (shells only) function
| Damage saturation for compression
transverse matrix exponential damage (shells
only). (Real) |
| Initial transverse damage threshold
in compression / Abscissa scale factor for tabulated damage
(shells only). (Real) |
| Critical transverse damage limit in
compression (shells only). (Real) |
| Reference strain rate for fiber
direction 1. Default = 1.0 (Real) |
| First parameter for Young’s modulus
strain rate dependency in fiber direction
1. (Real) |
| Second parameter for Young’s
modulus strain rate dependency in fiber direction
1. (Real) |
| First parameter for rupture strain
rate dependency in fiber direction 1. (Real) |
| Second parameter for rupture strain
| Reference strain rate for shear and
transverse directions. Default = 1.0 (Real) |
strain rate dependency in matrix transverse direction
2. (Real) |
modulus strain rate dependency in matrix transverse direction
2. (Real) |
| First parameter for shear modulus
strain rate dependency in plane 12. (Real) |
| Second parameter for shear modulus
| Reference strain rate for initial
yield stress. Default = 1.0 (Real) |
| First parameter for initial yield
stress strain rate dependency. (Real) |
| Second parameter for initial yield
| LTYPE11 | Strain rate dependency law type for
fiber direction 1.
(Integer) |
| LTYPE12 | Strain rate dependency law type for
shear and transverse directions.
(Integer) |
| LTYPER0 | Strain rate dependency law type for
initial yield stress.
(Integer) |
| FCUT | Equivalent strain rate cutoff
frequency. Default = 5 kHz (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
Test unit
Mg mm s
/MAT/LAW122/1/1
Steel
# Init. dens.
1.8E-9
# E1 E2 E3 G12 G23
135000 1000 1000 4000 4000
# G31 NU12 NU23 NU31
4000 0.33 0.1 0.33
# E1C GAMMA ISH ITR IRES
138000 1.7E-4 0 0 2
# SIGY0 BETA M A
20 0.7986 0.5166 0.33
# EPS_FTI EPS_FTU DFTU
0.002 0.0025 1.0
# EPS_FCI EPS_FCU DCFU IBUCK
0.0104 0.0105 1.0 1
# IFUNCD1 DSAT1 Y0 YC B
0.158 0.05
# DMAX YR YSP
0.95 1.5811 1.0e20
# IFUNCD2 DSAT2 Y0P YCP
0.158 0.05
# IFUNCD2C DSAT2C Y0PC YCPC
0.158 0.05
# EPSD11 D11 N11 D11U N11U
# EPSD12 D22 N22 D12 N12
# EPSDR0 DR0 NR0 LTYPE11 LTYPE12 LTYPER0
# FCUT
#enddata
/END
- The modified Ladeveze model considers a unidirectional composite ply
where fibers are to be oriented in the direction 1, and the matrix in the
transverse directions 2 and 3. This material orientation will then be
identified as
(Figure 1). The “out of plane” transverse
direction will then correspond to
-axis for shell and thickshell elements.
Figure 1. Unidirectional ply and its material orientation considered by /MAT/LAW122
- The elastic behavior is assumed to be orthotropic. Under 2D plane
stress conditions, for shells, the stress/strain relationship is given
by:
with
Where, .
This nonlinear evolution of compression Young’s modulus in fiber direction is used to represent the effect of fiber micro buckling and misalignment. is the shear factor used for shells only and defined in the property.
For 3D stress conditions (solid elements and thickshells), the inverse of compliance matrix is used to link the stresses with the strains:
The same non-linearity of fiber direction Young’s modulus in compression is used.
- In fiber directions 1 (or
-axis), the behavior remains purely elastic
until damage occurs (detailed below). However, the plastic behavior of the
matrix is considered under transverse and shear loadings. The elastic limit
is introduced through a yield function that differs from solids to shells:
- For Shells:
- For Solids:
Where, is a coupling factor whose value can be set to 0.33 for an isotropic resin. In this equation, the yield function is defined as:
This describes an isotropic hardening following a power law. The hardening modulus is numerically bounded by the value to avoid stability issues.
- For Shells:
- Like elasticity or plasticity, the damage behavior is assumed to be
orthotropic. Three damage variables are then defined:
and
which respectively describes the fiber
rupture, the shear matrix damage, and the transverse matrix damage.
- Fiber damage
affects the behavior along the fiber
direction 1. Under tension loading condition, fiber damage evolves
following the equations.Where, is the strain at the onset of damage, is the ultimate strain, is the ultimate damage value and is the equivalent fiber strain defined by:
- For Shells:
- For Solids:
The compression damage on fiber due to matrix buckling can be activated with the IBUCK flag and is described with a similar equation:
This fiber damage then affects the stress computation as:
Where, d' is the transverse matrix damage described below.Note: This new damage variable is introduced to consider coupling damage effect between fiber and matrix. Similar coupling is used if direction z is considered (for solid elements).Figure 2 shows the expected behavior in tension/compression along the fiber direction. The dashed line allows to highlight the nonlinear Young’s modulus in compression.Figure 2. Tension/compression test in fiber direction showing fiber damage effect on stress
Note: Along fiber direction, the behavior is purely elastic and damaging. - For Shells:
- Shear matrix damage
is introduced to represent the
debonding between matrix and fibers. Its evolution is influenced by
the energy release rate often used in Lemaitre-type damage model.
Two elastic energy rates are considered in this model.
- For Shells:
Where, are the Macauley’s brackets that only considers the positive values of . However, if compression damage described below is considered (for shells only), these brackets becomes simple parenthesis.
- For Solids:
This then leads to the following computation:
Where, is a coupling factor.
Depending on the value of the flag ISH, the shear matrix damage can evolve with different shapes.- ISH = 1: linear
shape (Figure 3)
Figure 3. Shear test showing shear matrix damage effect with a linear shape
- ISH = 2: exponential
shape (Figure 4)
Figure 4. Shear test showing shear matrix damage effect with an exponential shape
- ISH = 3: tabulated
shape (Figure 5)Where, is the function identified by IFUNCD1.
Figure 5. Shear test showing shear matrix damage effect with a tabulated shape
The shear matrix damage then affects the stresses computation as:- For Shells:
- For Solids:
- For Shells:
- Transverse matrix damage
allows to represent the
microcracking of the matrix. Its evolution is very similar to shear
matrix damage, except from the fact that a different elastic energy
release rate is used:Then, like shear matrix damage, three different evolution shapes are available depending on the ITR flag value.
- ITR = 1: linear
shape (Figure 6)
Figure 6. Tensile test in transverse direction showing transverse matrix damage effect with a linear shape
- ITR = 2: exponential
shape (Figure 7)
Figure 7. Tensile test in transverse direction showing transverse matrix damage effect with an exponential shape
- ITR = 3: tabulated
shape (Figure 8)Where, is the function identified by IFUNCD2.
Figure 8. Tensile test in transverse direction showing transverse matrix damage effect with a tabulated shape
This damage variable is supposed to occur in tension only. In compression, the microcracks of the matrix are assumed too close to recover the initial undamaged stiffness (Figure 9). However, for shells only, a specific transverse matrix damage evolution in compression can be described the same way using parameters: , , or IFUNCD2C.Figure 9. Tension/compression test in transverse direction
This last damage variable affects the stress computation with:Note: That additional terms are introduced when z direction is considered (for solid elements only), and a similar formula is used for the computation of the corresponding stress component . One can also notice that the coupling effect with fiber damage is similar to the one used for computation described above.
- ITR = 1: linear
shape (Figure 6)
- Fiber damage
- The last phenomenon represented in the modified Ladeveze model is
the strain rate dependency. Once again, it is assumed that the viscous
effects are not the same for the fibers and the matrix.
- In fiber direction, the viscosity affects the Young’s modulus
through the introduction of a rate factor denoted
Where, is the equivalent strain rate and is the reference strain rate in direction 1.
The rate factor equation can take different shape depending on the value of the flag LTYPE11:- LTYPE11 = 1: power
law
- LTYPE11 = 2: linear
law
- LTYPE11 = 3:
logarithmic law
- LTYPE11 = 4: tangent
hyperbolic law
The fibers failure can also be affected by strain rate through the introduction of the factor, whose evolution will also depend on the flag LTYPE11 using parameters and :
The expected behavior is detailed below in Figure 10.Figure 10. Strain rate effect on fibers direction behavior
law
- In matrix direction, the shear and transverse behavior are affected
by strain rate, as well. The elasticity is then modified with the
introduction of the factors
and
as follows:
You can notice that the two factors are using the same strain rate reference value and that , and are only modified for solids. The shape of the factors and will be fixed by the flag LTYPE12, and will depend respectively on the values of , and , .
The fracture energy is increased with strain rate, as well, using the same factors:Note: The compression damage parameter for transverse directions and are only modified for shells. - Finally, the last parameter affected by viscous effect is the
initial yield stress, with the use of factor
Similarly, the shape of factor is dictated by the flag LTYPER0 using parameters and .
The expected behavior for transverse matrix direction (which is similar for tension and shear) is detailed below in Figure 11.Figure 11. Strain rate effect on matrix transverse (or shear) direction behavior
- The different damage variable can be output using
/H3D/ELEM/DAMG/ID=Mat_ID with the
keyword MODE (=I or ALL).
The correspondences between modes and damage variables are:
- Mode 1: Fiber damage
- Mode 2: Shear matrix damage
- Mode 3: Transverse matrix damage
The global damage index is obtained by using /H3D/ELEM/DAMG/(ID=Mat_ID) without specifying any mode. It corresponds to the maximum between the 3 damage variables.
