Review and Edit Loads
Use the Details tab on the Load Cases table to review and edit loads.
To Do this
Rename a load or load case Double-click the load or load case in the table to make the field editable.
Change the magnitude of a load Double-click the magnitude in the table to make the field editable.
Delete a load Right-click the load in the table and select Delete from the context menu. Load cases can only be deleted using the Model Browser.
Sort a column Click the column header. Click repeatedly to toggle between ascending and descending order.
Show or hide columns Right-click on a column header and select which columns to show from the context menu.
Reorder columns Click and drag a column header to reorder the columns.
Insert rows Right-click a row in the table to open the context menu, and select Insert Row Above or Insert Row Below.
Select all table data Click the icon in the upper left corner of the table.
