Calculate Linearized Stress
Decompose a through-thickness elastic stress field into equivalent membrane, bending, and peak stresses for comparison with appropriate allowable limits. Linearized stress can be evaluated for structural linear analysis, structural geometric nonlinear and contact nonlinear analysis.
  1. In the Project Tree, open the Analysis Workbench.
  2. Click Pick info.
  3. In the dialog, select the Linearized stress tab.
  4. Optional: Enter the failure criteria for Membrane stress, Membrane + bending stress and Peak stress to see the pass/fail status of the created segment. The default values are calculated using the material’s yield stress.
    Membrane stress = 2/3 of Yield stress
    Membrane + bending stress = Yield stress
    Peak stress = 2x Yield stress
    When multiple materials are present in the model, the material with highest yield stress is used to calculate default allowables.
  5. Under Stress linearization segment, define the line segment in one of the following ways:
    OptionSteps
    Normal to surface Activate the Normal to surface radio button.
    SimSolid launches a ray which is normal to the surface and passes through the part.
    Custom
    1. Activate the Custom radio button.
    2. In the modeling window, pick the entry and exit points on the part.
      The entry and exit point coordinates are populated in the dialog.
    Normal to datum points
    1. Activate the Normal to datum points radio button.
    2. In the drop-down menu, select a point set.
    Linearized local stresses are evaluated on the fly and posted in the dialog for each line segment defined. By default, invariants are displayed in the table.
  6. Select the Show linearized stress tensor components check box to view stress tensor components along with invariants.
    Tip: Status of the line shows passed or failed based on the failure criteria. Failure criteria is only evaluated on the invariants.
  7. Optional: Save linearized stress information as a CSV file.
    1. Click Save to CSV.
    2. In the dialog, enter a file name and select a save location.
    3. Click Save.
Calculation Method
SimSolid method for calculating linearized stress.
Linearized stress decomposes a through-thickness elastic stress field into equivalent membrane, bending, and peak stresses for comparison with appropriate allowable limits.
Linearized stress is calculated as follows:
  1. The stress is extracted by interpolation in a local coordinate system at all the points along the line. The local coordinate system is based on the start and end points of the stress linearization segment.
    The X-axis of the system is along the segment from entry to exit points. The other two axes are calculated as follows:
    • If the local x-axis is not parallel to the global y-axis:
      Zlocal = Xlocal x Yglobal
      Ylocal = Zlocal x Xlocal
    • If the local x-axis is parallel to the global y-axis:
      local y-axis (Ylocal) is negative of global-x if local-x is along positive global-y, and vice versa.
      Zlocal = Xlocal x Ylocal
  2. From the extracted stress values above, the average membrane stress tensor + bending stress tensors at the entry and exit points are calculated using numerical integration.
    σ i m   =   1 L ∫ − L / 2 L / 2 σ i d x MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgaaeaacaWGTbaaaOGaaGPaVlabg2da9iaaykW7daWc aaqaaiaaigdaaeaacaWGmbaaamaapedabaGaeq4Wdm3aaSbaaSqaai aadMgaaeqaaOGaamizaiaadIhaaSqaamaalyaabaGaeyOeI0Iaamit aaqaaiaaikdaaaaabaWaaSGbaeaacaWGmbaabaGaaGOmaaaaa0Gaey 4kIipaaaa@4AAE@
    σ i S b   =   − 6 L 2 ∫ − L 2 L 2 σ i x d x MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGtbaabaGaamOyaaaakiaaykW7cqGH9aqpcaaM c8UaeyOeI0YaaSaaaeaacaaI2aaabaGaamitamaaCaaaleqabaGaaG OmaaaaaaGcdaWdXaqaaiabeo8aZnaaBaaaleaacaWGPbaabeaakiaa dIhacaWGKbGaamiEaaWcbaGaeyOeI0YaaSaaaeaacaWGmbaabaGaaG OmaaaaaeaadaWcaaqaaiaadYeaaeaacaaIYaaaaaqdcqGHRiI8aaaa @4E51@
    σ i E b   =   − σ i S b MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGfbaabaGaamOyaaaakiaaykW7cqGH9aqpcaaM c8UaeyOeI0Iaeq4Wdm3aa0baaSqaaiaadMgacaWGtbaabaGaamOyaa aaaaa@4432@
    σ i m MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgaaeaacaWGTbaaaaaa@39C3@ = ith component of membrane stress
    σ i MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aaS baaSqaaiaadMgaaeqaaaaa@38D0@ = ith component of extracted stress value
    σ i S b MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGtbaabaGaamOyaaaaaaa@3A90@ = ithcomponent of bending stress at the entry
    σ i E b MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGfbaabaGaamOyaaaaaaa@3A82@ = ith component of bending stress at the exit
    L = Length of the Stress linearization segment
    x = position of a point along the segment
  3. Peak stress and membrane and bending stress are also calculated at the entry and exit.
    σ i S p   =   σ i S   −   σ i m   +   σ i S b MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGtbaabaGaamiCaaaakiaaykW7cqGH9aqpcaaM c8Uaeq4Wdm3aaSbaaSqaaiaadMgacaWGtbaabeaakiaaykW7cqGHsi slcaaMc8+aaeWaaeaacqaHdpWCdaqhaaWcbaGaamyAaaqaaiaad2ga aaGccaaMc8Uaey4kaSIaaGPaVlabeo8aZnaaDaaaleaacaWGPbGaam 4uaaqaaiaadkgaaaaakiaawIcacaGLPaaaaaa@5488@
    σ i E p   =   σ i E   −   σ i m   +   σ i E b MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGfbaabaGaamiCaaaakiaaykW7cqGH9aqpcaaM c8Uaeq4Wdm3aaSbaaSqaaiaadMgacaWGfbaabeaakiaaykW7cqGHsi slcaaMc8+aaeWaaeaacqaHdpWCdaqhaaWcbaGaamyAaaqaaiaad2ga aaGccaaMc8Uaey4kaSIaaGPaVlabeo8aZnaaDaaaleaacaWGPbGaam yraaqaaiaadkgaaaaakiaawIcacaGLPaaaaaa@545E@
    σ i S p MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGtbaabaGaamiCaaaaaaa@3A9E@ = ith component of peak stress at the entry
    σ i E p MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4Wdm3aa0 baaSqaaiaadMgacaWGfbaabaGaamiCaaaaaaa@3A90@ = ith component of peak stress at the exit
  4. Finally, invariants for the membrane, membrane + bending, and peak stresses are calculated.
