SS-V: 6030 Simply Supported Thin Square Plate - Frequency Response
Test No. VD04 View frequency response of a simply supported square plate.
Definition
A simply supported thin square plate 10 x 10 x 0.05 m is subject to uniform pressure P=100 Pa which changes in time as the following function.
P = 100 ∗ sin ( ω ∗ t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8qrps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGqbGaeyypa0JaaGymaiaaicdacaaIWaGaey4fIOIaci4Caiaa cMgacaGGUbWaaeWaaeaacqaHjpWDcqGHxiIkcaWG0baacaGLOaGaay zkaaaaaa@45C6@
Where,
ω = 2 ∗ P I ∗ f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8qrps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacqaHjpWDcqGH9aqpcaaIYaGaey4fIOIaamiuaiaadMeacqGHxiIk caWGMbaaaa@40B2@
f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8qrps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGMbaaaa@39A2@
Excitation frequency.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
The material properties are:
Properties
Value
Modulus of Elasticity
2.e+11 Pa
Poisson's Ratio
0.3
Density
8.e+3 kg/m3
Note: This test is similar to Test VD01, but it is solved in frequency domain.
Results
The plate is simulated as a 3D solid body. Spot-lines were created at the mid-plane of the plate in order to apply hinge supports (Figure 1).
Peak response is reached when excitation frequency becomes equal to first natural frequency of the plate. Figure 2 shows frequency sweep result for Y-displacement amplitude in picked point with coordinates [m] X = 4.9469, Y = 0.05., Z = -4.9158.
Figure 3.
The following table contains peak response comparison.
Deflection Y Amplitude, mm Surface Stress Amplitude, MPa
45.68 32.08 SimSolid, 3D solid model
45.42 35.08 Reference, thin plate model
1 Test 13H from NAFEMS Publication R0016, “Selected Benchmarks for Forced Vibration” J. Maguire, D.J. Dawswell, L. Gould
