Measuring a Distance
The measure distance tool allows you to measure or validate the physical distance between two points in a model.
On the Tools tab, in the
Tools group, click the
Measure Distance icon.
- Under Point1, use Ctrl+Shift+left click to snap to points (for example, named points, geometry points, geometry face centre, geometry edge centre, mesh vertices and grid).
Repeat Step 2 for
Point 2.
The total distance, as well as the individual X axis, Y axis and Z axis distances, are displayed in the Distance (D), X distance, Y distance and Z distance fields respectively.
Click Close to close the dialog.
Figure 1. The Measure distance tool.
