Adding a Quadcopter from the Component Library
Select a simplified quadcopter model from the Component library and add it to the project.
On the Home tab, in the
File group, click the
Component Library icon.
On the Component Library dialog, in the
Filter field, enter the text
quadcopter.
Figure 1. The Component Library dialog. - From the filtered results, click Quadcopter - Simple.
- Click Add to model to add the quadcopter and to close the dialog.
On the Align dialog, under Destination
workplane, in the Origin field,
Z field, enter -100.
Figure 2. The Align dialog. Note: The offset separates the patch from the quadcopter on import. - Click OK to place the quadcopter and to close the dialog.
