The feed is constructed using a line and fed using a wire port.
A feed structure (a line) is added to both sides of the microstrip line to connect the
microstrip line to the ground plane. A wire port is added to the feed structure.
Figure 1. Isometric view of the partial microstrip line. The feed structure is a line
(highlighted in yellow) and fed using a wire port.
