The component library consists of two main panels.
The first panel allows you to browse through the available components. The second panel
(only applicable to antennas) allows you to refine the selected antenna.
Figure 1. The Component library dialog. On the left, the first panel for browsing
components and to the right, the second panel for refining the
component.
Components
View the list of components (antennas and platforms) in the
component library. Find a component quickly by either entering
filter text or filter the list according to the component type.
To select a component, click on an item in the list.
Geometry preview / results
View images of the selected component in 1.
Click on an image to maximise and click again to minimise.
View a summary of the selected component in 1, as
well as keywords relevant to the component.
Tip: Use the
keywords as filter text in 1
to find similar components.
Antenna settings
Refine the selected antenna with additional options and
settings.
Click the icon to view the
solution methods in the Feko
documentation.
Solver information
View a summary of the solution methods that can be selected to solve
the antenna. Not all solution methods are supported for each
component due to differences in how the component model is set
up.
