Creating a Characterised Surface
Define a surface that is characterised by previously obtained data in a .tr file.
Note: Only supported in conjunction with the RL-GO
solution method.
On the Construct tab, in the Define group, click the
Media icon.
From the drop-down list, select the
Characterised Surface icon.
Figure 1. The Create characterised surface medium dialog.
- In the Filename field, browse to the location of the .tr file.
- In the Label field, enter a unique label for the characterised surface.
- Click Create to define the characterised surface and to close the dialog.
