Accessing the Periodic Structures Tab on the Ribbon
Open the Periodic Structures tab on
the ribbon to access advanced tools related to defining periodic structures.
By default, the Periodic Structures tab is not displayed on the
ribbon. To access the Periodic Structures tab, you must configure the ribbon to show the tab.
On the Home tab,
in the Extensions group,
click the Periodic Structures icon.
When the Periodic Structures tab is enabled, it is located on the ribbon between the
Transform tab and
Source/Load tab.
Figure 1. The ribbon in CADFEKO
(Periodic Structures tab)
