Model Protection Limitations
There are various restrictions on simulations that include password-protected models. Some restrictions are imposed to protect the information contained inside the protected model, while other restrictions will be lifted in future releases.
The process of running a simulation with a model that includes imported protected models is the same as for a model that does not contain imported protected models. Various limitations on output file formats and solution output will be imposed when parts of the simulation are protected. Some parts of text files (such as the .pre file) will be encrypted and will not be editable or readable. The solver will limit details written to the screen as well as output files and certain output files, such as export of files for thermal analysis, are not supported and if requested, the setting to write out these files will be ignored.
Requests
Some requests, most notably currents, will be excluded from the simulation even if the requests are defined. Near fields can be requested and will be calculated, but only the results that fall outside the bounding box of the protected part will be available. Warning and error messages in the CADFEKO notification centre will indicate where these limitations are applied.
Solution Methods
| Protected Component | Rest of Model | |||||
| MoM (incl. SEP and VEP) | MLFMM | PO | RL-GO | UTD | FEM | |
| MoM (incl. SEP and VEP) | Yes Windscreen method may be used in the rest of the model. |
Yes MLFMM will be applied to the full simulation. |
Yes | Yes | Yes | Yes Connections or intersections involving FEM regions may not be supported. |
| MLFMM | Yes MLFMM will not be applied to the protected component. |
Yes | No | No | No | Yes |
| PO | Yes | Yes | Yes | No | No | No |
| RL-GO | Yes | No | No | Yes | No | No |
| FEM | Yes | Yes | No | No | No | Yes FEM regions in the protected component and the rest of the model should not intersect. |
2D Results in POSTFEKO
Results can be plotted on 2D and surface graphs and post-processed as normal.
3D Results in POSTFEKO
Results that can be viewed in the 3D view (such as far fields) need to be copied to a custom dataset before adding them to a 3D view.
