Requesting Ideal Receiving Antenna (Near Field Pattern)
Add an ideal receiving antenna (near field pattern) request to the model.
On the Request tab, in the
Solution Requests group, click the
Receiving Antenna
icon. From the drop-down list, select the
RX Near Field Antenna icon.
Figure 1. The Request Receiving Antenna (Near Field) dialog.
Define the near field aperture using one of the following:
- To create a single near field aperture using individual near field
definitions, click Combine individual faces.
- In the Field data column, specify the field data for each face.
- To create a single near field enclosed region, select
Reference an enclosed region of surfaces.
- Specify the field data and location of the region.
- In the Label field, add a unique label for the request.
- [Optional] Click the Advanced tab. Select the Include only the scattering part of the field check box to ignore the radiated contribution from impressed sources as well as the contribution from plane wave sources, yielding only the scattered fields.
[Optional] To consider (as part of a single Solver run) the impact of a ground
plane definition on the computed receiving antenna derived during
post-processing of the core solution, click the Plane /
Ground tab. From the Definition method
drop-down list, select the ground plane type.
This approach enables a fast and efficient way to consider the impact of different infinite ground plane definitions on a solution.
Note: To use this option, the plane / ground of the model must be set to No ground. - Click Create to request the receiving antenna result and to close the dialog.
